Results with FM Trap
When I installed the 7967, I removed the HLSJ from the cable run. (Since I was having issues with both it & the previous antenna) I reinstalled it and it did improve the reception on 9-1. During a brief test, no dropouts and greatly reduced pixelation. I'll terminate the low end to see if it makes a difference in my case.
The leaves are beginning to drop here, in the past this increased the dropouts/pixel problems. Will play with the position little by little to see what works best.
I am replacing the cables & grounding block to remove an open terminal on the ground block. Is it good practice to seal the coax connectors at the block to prevent weather intrusion?
Also, not using a Channel Master 7000. Thanks for all the help.
