Old 12-Mar-2013, 5:56 PM   #3
A Repeated and Common Situation is PC tuner cards that are designed to be not as good as tuners in most Tv's.
There Are No stronger tuner cards that I know of.
_____________________________
Also a Repeated and Common Situation is , TIVO's , Do Not have tuners that are as good as tuners in most Tv's.
The tuner cards and tuners in Tivo's are designed to be less capable.
The PC tuner cards and Tivo tuners do not deal well with , Multipath/Reflected Signals and Weak Signals.
The tvfool report you have provided says , Address was only resolved to block level and might not be that close to your actual location. For more accurate results , try entering a specific address and coordinates.
Also the tvfool report is not showing any antenna feet above ground.
Please make a tvfool radar report with the Exact address and if antenna height is more then 25 feet above ground the use that antenna height to make the tvfool report.
If antenna is less then 25 feet then -->Use a 25 foot antenna height to make the tvfool report.
Do not delete the first tvfool report that has no antenna height in the tvfool radar report.
