Lost OTA Signals
No, just the two that connect to the grounding block, (1 in, 1 out) the grounding block is new since the old block had some corrosion on the interior of the 75 ohm connection. I also used silicone di-electric grease
in the 75 ohm connectors.
Reason: add'l info
