For the only viewing antenna , Antenna rotators Are Not <->Channel Surfing Friendly. Must wait for antenna to rotate and --> There Will Be --> Domestic Situations about the aim direction of the antenna.
___________________________________________
Antenna system #1. New York.
Winegard HD7084P antenna with a Winegard AP8700 preamp , aimed at about 75 degree magnetic compass direction. Here is how to aim antennas ,
http://www.ronard.com/909911.html , if using the tripod antenna mount use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , if using the eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the sloidsignal search box or buy from ronard.
Here are some places to buy antennnas and etc. ,
http://www.solidsignal.com ,
http://www.amazon.com ,
Install the preamp power supply and power injector ahead of the splitter.
______________
Each time a splitter split happens , the signal strength is reduced.
Use splitters that have the number of output ports to the number of Tv's.
Examples: For 2 Tv's connected , do not use a 4 way splitter or a six way or 8 way splitter.
Use a 2 way splitter for 2 Tv's connected.
And so forth.
The best way to do coax wiring is to have 1 splitter that has the number of output ports that is the same as the number of Tv locations.
Or a sight variation , Example: 5 Tv's connected , it is Ok to use a 6 way splitter.
And from the 1 single splitter , coaxes will go out to each Tv location with no other splitters connected.
 As a ->Test<- of reception , Antenna system #1 , can be aimed at New York , 75 degree magnetic compass direction -> Or At <- Philadelphia About 235 degree magnetic compass direction.
If will like to receive both directions.
I recommend , Antenna system #2.
Antenna system #2 is the same setup as antenna system #1.
The 2 antenna systems are separate antenna systems all the way to the Tv locations.
At each Tv location will be a , Remote control A/B antenna switch.
A/B antenna switching --> Is Channel Surfing Friendly , press the button on the hand held remote , Change Antennas and Keep On Channel Surfing.
http://www.mcmelectronics.com
