Why wouldn't the antenna be pointed SW directly at the stations in NYC?
Yeah, that was the point I was making.
would I be able to do it with the Winegard 7698P?
Absolutely, but either a rotor or a two-antenna system would be needed for reception of both markets' stations.
Would this be viable for me since my 2 primary areas are 180 degrees apart?
Your forecasted signals strengths are below what I would consider acceptable for a low-gain, bidirectional configuration. You could give it a try with a pre-amp and it would work somewhat, but my confidence level is low it would work out.
