If you want both CT & NY channels, you want antenna which can get both front as well as back or have 2 antenna. In that case, Winegard 7698P on the roof pointed at 90 degrees magnetic might be a better option.
However, if you are content with just NY channels, C4 & C5 might be an overkill. Get a C2V pointed at 180 degrees magnetic. I personally am in CT and use C2V to get CT ABC, NBC, CBS & FOX channels.
Dinesh.
