Old 15-Jan-2013, 6:42 PM   #4
Try the C2V instead of the C2. Channels 7, 8 (Edison), 11, & 13 are your local high-VHF stations.
Channel 9-2 is broadcast as a sub-channel on one of the UHF stations.
WPXN operates on UHF 31 with a highly directional transmitting antenna that faces away from you. Not much of their signal power is coming your direction which will make that station particularly susceptible to multi-path. Try the antenna in various locations and orientations to see if you can improve its reception.
