Old 8-Nov-2012, 3:15 AM   #5
Ok , the top of a 3 story house will be more then good for Digital Tv Reception.
Due to the Well Known situation with KCWX VHF low band channel 05 , MyNetwork and This Tv. http://en.wikipedia.org/wiki/KCWX.
And KCWX VHF high band channel 08 that will not be on the air until the middle of 2013 and will be a fill in transmitter.
KCWX channel 05 will remain the primary signal.
_______________________
A All channel antenna is required.
I recommend a All Channel antenna , all channels are ,
UHF band channels 14 thru 51.
______________________________
Above the roof install a Winegard HD7000R antenna aimed at about 210 degree magnetic compass direction.
No preamplifier is required.
For 1 Tv connection use No splitter.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 tv's connected use a common simple 3 way splitter.
___________________________________________________
The HD7000R antenna is a little directional in the forward direction , and that's good for the reception of channel 05.
However the HD7000R is not all that directional.
And will receive the strong signal strength Digital Tv stations to the , North East , South East , South west , West.
And that is all the Digital Tv stations that are required to receive.
Guy wires Are Not used for mounting the HD7000R above the roof.
A simple antenna mount such as , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html #4560 , http://www.ronard.com/ychim.html , http://www.ronard.com.
____________
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to install antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , some times named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
