Single antenna reception solution
For a single antenna set-up, I recommend you install an Antennacraft HBU55 antenna and a Winegard AP8700 amplifier. Use a Channel Master 9521 rotor to change directions for reception of the duel markets and more.
For a two set hook-up install a two way splitter with a DC path to provide un interrupted power from the power supply to the amplifier.
When installing, be sure to set the rotor to end of rotation, then aim the rotor and antenna to magnetic North. With that you will be able to use the TVF report to locate all of the channels on the report.
