Originally Posted by teleview
For 1 Tv connection use no splitter.
For 2 connections use a , HFS-2D , 2 way splitter.
For 3 connections use a , HFS-3D , 3 way splitter.
For 4 connections use a , HFS-4D , 4 way splitter.
Buy the HFS splitter at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
____________
Are the HFS splitters ref'd above satellite dish splitters? Will they work to split OTA antenna signal?
I have tried a 3way splitter and have great results still, but need a 4way.
Also, does anyone know if the newer dual HDHomerun (with single input) has signal loss when the signal is split inside the unit?
I hooked an amp (Electroline EDA-2100) up near the antenna, and am sending the signal over a 35 ft coax now. To be split four ways to:
TV
HDhomerun dual (dual coax input)
HDhomerun dual (single coax input)
Thx again!!
