Old 28-Sep-2012, 9:50 PM   #6
If shopping on Amazon, use Model "C2-V-CJM" as your search string. This is a new version that just started shipping in the last six weeks.
Notable differences between it and the ClearStream 2 Complete we have been selling for the last year are:
1) Coax cable is not included in the SKU, purchase amount needed separately.
2) The reflector grid is now riveted onto the vertical support and will require drilling to remove the reflector. It may be areattached with standard #10 hardware, if required.
3) The function of the UVSJ, previously a separate device mounted to the reflector, is now integrated into the loop assembly along with the UHF balun. There are now two F-connectors on the back of the loop, one for the VHF dipole to connect, one for the coax out.
4) The loop element base now has two holes for cable pass-through.
5) The VHF dipoles are a bit longer for better VSWR and are now powder-coated black for a "stealthy" appearance.
The original C2 Complete will remain available until existing stock is depleted.
An additional SKU "C2-V" will be available soon and will be the antenna only, not accessories.
As of today, Amazon finally got the correct photo up for the C2-V-CJM. It had the photo of a different version of the C2 posted since early August.
Cheers!
