If there's a dilemma, it's that more gain in the CH-2 range would be desirable. But an increase in antenna gain comes at the expense of narrow forward beam width which could make simultaneous reception of the NE & NW signals unreliable.
Of the antennas you've listed, the HD7000R is the best fit for your situation. Also consider the Antennacraft CS600.
If you have several sets to connect, consider using an Antennas Direct CPA-19 preamp or a Channel Master CM-3410 distribution amplifier.
