I just put up 2 antennacraft 54 inch antennas stacked one about 8 feet above the other ,the bottom one is about 18 ft off the ground.2 coaxes from each antenna eaqual lengths into a combiner into a rca "walmart" preamp then to a spliter in my attic to 2 tvs, I was thinking that i should be able to get alot of channels,but it seems so direction sensitive one way i get 7,9,12,22, but not 14, 19,50 or 5 and then vice versa.which way shoud these antennas point? which side of the antenna is the front? why does my panasonic tv pull these signals out so much better than my hitachi tv? both flat screens,tried only one tv at a time also,seems the tuner on the hitachi just struggles to tune,any ides anyone.the panasonic 32 inch has no problems i get like all the channels with no problem, oh yeah I have a rotor on this setup also,but i dont want to have to turn it all the time. my zip is 28513. any suggestions any one?
http://www.tvfool.com/?option=com_wr...2df952a59979ac
