I've been through this problem more than once. Indoor antennas pale in comparison to outdoor antennas even when used indoors. Find a good indoor antenna like the CM 4221 which you can mount inside in a window by simply perching it on a unused chair. It will give you every UHF signal in green and probably those in yellow. It might give you 8 and 10 too though I am not completely certain about that.
I was able to get VHF hi with my 4221 when I tested it in the Hartford area last fall. And in my current location, I've used a 4221 in my living room and received every KC signal in yellow on my TV Fool report though all are UHF signals. I am 35 to 40 miles from every transmitter!
