Old 12-Sep-2012, 12:16 AM   #2
ALL questions and answers about broadcast tv reception and More.
The following is a Teleview recommendation for broadcast Tv reception.
Antenna system # 1.
Above the roof aim the DB4 with a Antennas Direct CPA-19 preamp at about 200 degree magnetic compass direction.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
If , WFSA NBC , WCOV FOX , WBMM CW and ABC , WGIQ PBS , WIYC Weather Nation , are received , then you are good to go for those directions.
If WFSA-DT - NBC that is on real VHF channel 12 is not received with the DB4 antenna , then add a Antennas Direct C5 , VHF antenna aimed at about 228 degree magnetic compass direction. The C5 Vhf antenna comes with a combiner that connects the DB4 and C5 together on to one down lead. the CPA-19 preamp is connected to the output of the combiner.
________________________________________________________________________
Antenna system # 2.
For reception of , WRBL CBS and ME-Tv , WXTX FOX and This Tv , WTVM ABC and Bounce , WYBU Religion , WLTZ NBC and CW
Above the roof install a Winegard HD7698P antenna with a Winegard AP8700 preamp , aimed at about 110 degree magnetic compass direction.
For 1 Tv connected do not use a splitter.
For 2 Tv,s connected use a , HFS-2D , 2 way splitter.
Antenna systems 1 and 2 are not connected together on to the same coax.
The 2 separate coax and antenna systems go to the locations of the Tv/s and are connected to a A/B antenna coax switch , http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #34-4425 .
Here are places to buy antennas and etc , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
It is best to install the antennas at a location that has the least amount to no amount of obstructions in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels or ' Antenna channels' in the Tv set up menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
This 2 antenna systems set up is Channel Surfing Friendly , press the button on the hand held remote control , change antenna systems , and keep on channel surfing.
Another way to do it is to use a antenna rotator , antenna rotators are not channel surfing friendly , must wait for antenna to rotate.
And not every one in the house will agree on where the antenna is pointed.
