I hate how some tip-toe around these questions.....Tower Guy gave you the answer...you're starting from scratch, get both VHF and UHF on the start-up...pick one of the antennas TG suggested....
If you're worried about aesthetics, you might consider climbing back on the satellite/cable train, aesthetics are not part of good OTA reception if you want the best signal and all the channels you can get (which is what you want, and will find out why you want it once you stick some aluminum in the air and find out OTA is no where near sat/cable dependability...you WILL work for it).
Good luck....
