As I said , the antenna can not be connected to a coax line that has cable delivered internet service.
A separate coax must be run for either the Cable coax or the Antenna system coax.
The antenna system can not be connected to Any type or kind of Active cable delivered services.
Yes you can use coax that is in or on your house for the antenna system coax as long as there is no active cable service on the coax.
If you only require Cable internet service to one location , then all the other coaxes can be disconnected from Cable and used for the antenna system.
Concerning the antenna rotor , do not use a antenna rotor , aim the antenna as directed.
