@ Billiam: just to clarify things for me, are you suggesting replacing the DB4e with a CM 3023 or are you suggesting introducing a third antenna into the mix? Wouldn't the DB4e pick up those 2 stations as well? The CM 3023 does it better?
In general, I'll just mention that there are hook ups for tv's wired into 5 rooms but only 3 tv's are hooked up (and only 2 really being used). I can unhook unused rooms if that would be better. Irregardless, you all seem to be saying more than one tv demands the use of a preamp.
If I choose not to worry about 4, 10. & 23 and only concentrate on the two main groupings, would the CS 2 Complete recommended early on by "signals unlimited" do the whole job for me? Seems to me it has it all (lo & hi VHF & UHF). Or is there an inherent value to utilizing two antennas in situations like this?
I look forward to anymore input and I'll then make my decisions. I'll post back to share the results and say "thanks". I appreciate everyone's help.
