Greetings Sean,
I don't think that using two Antennas is the answer.
You have good reception numbers, all in the same direction (153-163°).
Trying to get the ones in other directions, only would be duplicates.
I'd try a...
Antennacraft HD-850, or
Terrestrial Digital V-15.
There are several other Modified (Ch 7-69) Antennas which would work as well, except that the above have FM Capability as well.
With the above Antennas, I'd suggest using a...
Winegard CA-8800 FM Splitter in your Theater Area, which could cable over to your FM Receiver.
Good Golf, good OTA/HDTV and anything else that makes you HAPPY
OTA: AntennaCraft/RS VU-90XR (Attic Mt). DTVPal DVR, Sony RDR-VXD655, WinTV HVR-850-1200.
D/A: Samsung H260F, Winegard RC-DT09A, DTVPal Plus.
Typical OTA Reception Houston TX 77033
