Going higher, clearing the roof. These are good moves. The problem is that when you clear the path for reception from other directions, your antenna may need to be rotated also. The CS2 is somewhat dirrectional. Another consideration is the distance to the new group of stations. Reception of stations over 40 to 50 miles may require an amplifier.
A rotor and an amplifier will deliver the other stations, but it's a little tricky to set-up. Let me know if you want to go that route and I will be glad to walk you thru it.
