With the large trees in both directions, tuning and locating the antenna is a challenge. Relocating to the other side of the house may or may not improve the reception. If it my installation I would do two things: Mount on your Hip roof, with your "J" pole and install a rotor. This will give you the ability to tune the directions of indivisual stations from a more advantagous location. I would also suggest changing into an RCA ANT 751 antenna.
If you want to use a rotor, the Eagel Aspen Roto 100 will operate thru your RG6 coax.
This will resolve your problems as best you can, taking into consideration your obsticals.
