If you can put a Tv antenna on the roof. Can you put a antenna on the roof??
Aim a Winegard HD7000R antenna , no amplifier , at about 258 degree magnetic compass. About 258 degree magnetic compass , WNJB 8 PBS , is in the middle of the groups of Tv stations to the north/west , west , south/west , south. Starting with the antenna aim in the middle of the groups of Tv stations will get you the Tv stations to the , north/west , west , south/west . south.
Here is how to aim antennas ,
Here are places to buy antennas and etc. ,
http://www.solidsignal.com ,
http://www.winegarddirect.com ,
http://www.amazon.com.
Here are some antenna mounts ,
http://www.ronard.com/909911.html ,
http://www.ronrad.com ,
http://www.ronard.com/ychim.html ,
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
If there is a , north/west , west , south/west or south facing balcony the HD7000R antenna can be put on the balcony and aimed south/west. The tripod antenna mount makes a good stand for a antenna on a balcony.
The HD7000R could be in the apartment and aimed out a south/west facing window. The tripod stand makes a good stand for antenna in the apartment.
Could also use a Terk HDTVi indoor antenna aimed out a , north/west , west , south/west , south , facing window.
Here is how to aim indoor antennas ,
The best place for reception is a roof top antenna.
Then a balcony.
Then indoors.
The best way to get a coax from the outside of a building to the inside of a building is a hole through wall.
Another way to do it is , Holland 144823 flat cable , at solidsignal.
