Thanks.
The direction is towards VT. to pull in the local US networks.
The local channels (10 miles) I can probably pull in with a coat-hanger...
I will look at the winegard (you own stock?)
I am thinking the cost/complexity (multiple antennas/rotor config) outweigh the benefits of the stations in 220-330 degree range .
I will go without a rotor still thinking of the HBU 44... dont know if it gets me much...
Why will the local stations screw with a pre-amp like the CM 7777??
