Satellite splitters must be replaced with splitters designed for DTV. They They are typically will be 50 - 1000 MHZ. The coax will be re-usable. Remove everything in the path from the antenna to the DTV sets and replace with DTV products. Be sure that your DTV sets are configured to receive ANTENNA not cable also look for an option that says AIR, then scan channels. You will find these option in your menu.
