Two antennas on single mast
I am adding a low band VHF (Ant Direct V4) to my rig, which has a yagi style XG91. Ran this by tech assist at Antennas Direct and since I am already picking up reliable high band VHF with the yagi, the low band should be perfect addition. So, is it appropriate to have both on the same mast?
Should cabling from the combiner to each ant be of identical length?
Thanks in advance.
Best,
David
