					Originally Posted by MisterMe  If you remove power from a preamp, then it becomes an attenuator. It is not surprising that you receive nothing. Remove the preamp completely, connect your coax downlead directly to your balun, then retry. If you still receive nothing, then take your problems to the Help With Reception area of this forum. Follow the steps for requesting help. |
 Hi Misterme,
Thanks for your reply. I already wrote in my first post that I do get picture with and without preamp. Only problem is that the signal level does not change at all.
Thanks
