Thank you for the information! I am suspect of the amp. It claims to use low noise margin circuitry but does not give a rating. The amp does help in that there are channels which completely drop off with it however the fact it does not list a noise margin scares me. I have some channels that drop in and out and was thinking i could gain some strength if I go to an amp with a lower noise margin? If I understand correctly if i go from an amp with a noise margin of 8DB to 3DB that is the same as picking up 5 DB in antenna gain?
