Thanks for the great advice.
I will look into doing the cable splitting better as suggested. (I did not install original config. Though, if I had, I may have done worse : ) From your suggestions, I'm leaning toward replacing the Terk, which if I did, I'd go with the ANT751 or the Winegard HD7694P b/c I'm confident the space in my attic (not all that large) would accommodate either. I like that the ANT751 comes with mounting hardware, but I suppose I should go with the 7694P since it has a bit more range, and I really want to get the job done. As for mounting an antenna above the roof, that would run afoul of neighborhood association restrictions.
Thanks again,
Jim
