Originally Posted by olimazi
the best place to place my antenna is on the chimney for my boiler exhaust.
For one it's smaller than my fireplace chimney and it smokes alot in the winter - so a little worried about high winds and a big antenna cracking the chimney, and a little less worried about fumes degrading the signal.
How small of a chimney are you talking about? and what is it made of?
So far, I have never heard of anyone breaking a chimney due to a TV antenna. I suppose anything is possible, but chances are that the antenna mast will bend or the chimney mount itself will break (causing the antenna to fall over) before the chimney gives way. I've seen bent masts and broken mounts, but never a broken chimney.
The antenna should be at least about 4-5 feet above the roof. Don't go any higher than necessary and you can keep the stress on the chimney, mount, and mast to a minimum. The peak stress levels go up approximately with the square of the distance from the mounting point, so if you double the mast length, you almost quadruple the peak stress at the mount.
For taller mast installations (perhaps because neighboring buildings or other obstructions make antenna height a necessity), I recommend using guy wires (usually if the mast is over 10 feet). This will offload a lot of the lateral stress on the mast, leaving mostly downward force on the mount.
I will be installing Solar panels soon on the roof - should I be worried about my reception witht he antenna and the panels up there?
Probably not. As long as the antenna is at least 4-5 feet above the roof, I wouldn't anticipate any problems.
The antennas are designed for ideal operation in open space (that is, no other objects around them, especially metal). The mast is already factored into the design, so it is safe to use a vertical metal mast. The influence of other nearby objects falls off with the square of the distance, and usually, by the time you are more than 1 wavelength away from the antenna, the effect is starting to get very small. The wavelength of channel 7 is approximately 5.6 feet. The wavelength of channel 36 is approximately 1.6 feet.
Even if you have objects less than 1 wavelength away (like for channel 6, having a wavelength of about 11.6 feet), it does not necessarily mean that anything bad will happen. It just means that the potential exists for the antenna's behavior to change at those frequencies.
With the antenna 4-5 feet above the roof, you should be pretty safe. This should be enough distance such that even after the solar panels are installed, any influence that they might have would be small or negligible.
