@luvhd, your link is 'pointing' at the data input page rather than the actual link to your TV Fool Report. Can you generate a new TVFR and then cut & paste the link from your browser address bar?
Thanks.
I would expect that we will be able to help you find an antenna that can feed directly into your TV tuner. A TV equipped with an ATSC tuner should not need an external tuner/converter. Most TVs need to be setup to use the ATSC tuner. The setup menu system typically provides an antenna or air option versus cable mode. If the TV is in cable mode, it will not decode over the air digital signals.
