Old 24-Mar-2012, 7:40 PM   #1
kjs5555
seattleTV
antenna signal on existing home coax?
hi all - just starting the liberating process of cutting out digital cable from my life. I will be adding an antenna in the attic for starters. Ideally I am hoping to use the existing coax throughout my house to get the signal in 4 rooms with TVs.
I also plan to keep my Comcast cable for high speed broadband and phone in the house
Questions:
1. Can I somehow put the antenna signal on to the same coax home network? Will it interfere with the Comcast broadband?
2. If the signals don’t interfere with each other, how do I get the antenna signal on the coax cable along with the Comcast signal?
3. Can one antenna service my entire house (4 TVs, rough house size 3500 sq ft 2 stories so I have some lengthy coax runs)?
kjs5555 is offline   Reply With Quote
