Since the dig channels have all moved to UHF, all we see are WNET (still a hold over on VHF) and one or 2 others.
Um, no. VHF is still used in the NYC as you have full-power stations on VHF channels 7, 11, and 13. Low-VHF has, in your area, been relegated to low-power digital or Franken-FM service on channel 6 (which will end in 2015).
If you'd like to use a single antenna for both TV and FM reception, stick with a conventional all-channel antenna that specifically states it may be used for FM as some models may have provisions for reducing FM due to interference concerns.
