Without braces on the J pole , The antenna Will Fall Over ,
http://forum.tvfool.com/attachment.p...8&d=1326042321 , It is recommended to use a Very Strong antenna mount. The HD7698P antenna is not cheap , If I were mounting the HD7698P antenna I would not cut corners on the mounting.
