Today I have run into problems.
I was seeing occasional dropouts on a station I was watching (I forget which one), then it stayed a blue screen saying "Unusable signal".
As I started trying other stations, they all were saying "Unusable signal".
I did a new channel search & it found no stations.
I checked connections at both ends of the coax cable (including the two wing nuts on the antenna).
Then just for fun I tried the "channel search" two more times, each one after moving the antenna.
The TV still says it's not finding any channels.
I wonder if the "matching transformer" that came with the antenna may have gone bad?
Thanks for any help you can give me. ...Tim
