This thread is specifically open to technical hair splitting.
Originally Posted by Electron
The Milky Way ????????????? This technical hair splitting can go on till the end of everything. The result is the question askers are _____________ out of receiving VHF low band channels 2 thru 6 because of the doubt. The question askers are told not to think about it and do not do it.
If you believe I or others are overly conservative when making L-VHF reception equipment recommendations, please make your case. Feel free to answer"...what is a practical minimum NM goal for reliable reception in the low-VHF band?"
Please expect to be challenged to provide support for your answer to the above.
Reason: Removed tangential comment
