The WA830TG is marketed using several other names and model numbers. I can't help but wonder if they need to keep changing the identity so often because each name and model number combination develops such a negative reputation. Jammed rotator, short life of plastic parts and grossly inflated performance claims seem to be common.
Please consider starting a new thread in the Help With Reception Forum.
Guidelines when asking for help - With an accurate TV Fool report we can recommend an antenna that fits your needs.
