Channel Master CM-700X
The CM-7000 is no longer stocked as "NEW" at the Chanel Master store. You may be able to find an "Open Box Special" or if you can find one used, it is known as one of the higher quality STB/DTV converters from the $40 government coupon days. It was one of the few STBs with S-Video output. (I don't understand why Channel Master used confusingly similar model numbers for different products. I am not referring to the CM-7000PAL in this case.)
The CM-7001 supersedes.
With HD capability and HDMI interface the CM-7001 is worth looking at though the price is about $130.
The CM-7001 is reported to have minimal EPG functionality.
Reason: Added links for the 7000 vs. 7000PAL
