Old 1-Dec-2011, 2:30 AM   #1
pqgh001
Help with antenna choice
Hi,
Here's the tvfool report:
http://www.tvfool.com/?option=com_wr...ec128a5e5ecb19
I have tried:
1. Channel Master 2016 pointed to west from the 1st floor of my house and received
21-1 wfmj
21-2 wbcb
33-1 wytv
33-2 my ytv
33-3 weather
No other directions have worked with this antenna. I must point out that one of the fins holding the cable connector was broken off the main rod, but held approximately in proper place and direction
2. Artec Digital TV Antenna with Flat Panel, AN1 Indoor Digital Flat Antenna
pointed in the same direction picked up:
21-1 wfmj
21-2 wbcb
27-1 wkbn
27-2 wyfx
Obviously, the Channel Master 2016 will be returned or exchanged. I have 4 tvs around the house and the antenna can be installed in the attic or up about 20 ft on the roof. I have 2 coax runs from the roof from old dish installation into 2 splitters feeding those 4 tv runs inside of the house.
Should I get the same 2016 or do you have any other recommendations for all 6-7 channels?
Thank you in advance.
pqgh001 is offline   Reply With Quote
