Good rotor. I own one and like it. It will easily handle much larger antennas if needed. I have an HBU 55 on it and it works great.
The pre amp you've chosen is usually the one people recommend for stronger signal areas. So, this should work especially if you get the antenna up a little higher. At ten feet you have too many obstacles in the way of the signal to the antenna.
