The PA18 will overload in this location. Select the CPA19 instead.
There is no need for an all-channel antenna in this location unless you really want Daystar, the only programing that is unique to the low-VHF band in this area.
You'd do best to first investigate the fare available separately from the Chico or the Redding locations and determine of you want both or only one of those markets. Only then can an informed recommendation be made based on YOUR requirements.
