Thanks for recommending model numbers of antennas, mtownsend - didn't know where to begin?
Good info about staying away from the metal roof. To keep it away from the roof, could we could use a sailboat mast that we use as a flag pole now? Does the antenna need to be stable - ei:not swaying on the end of a mast?
As far as hurricanes go your concern is warranted. One good thing about hurricanes is they don't sneak up on you, I could remove it before the real wind started.
Does an amplifier help in this case or is it best to stay away from them... same for a rotor?
