Originally Posted by k3n0bl
The angle I'd have to go is right through some trees, not sure how realistic this whole thing is.
The predicted signal levels and interference for reception of WBNS is marginal. Add the trees and some inexperience, I'd rate your chances for success at less than 50%.
My own quest for additional NFL regional games has been mostly unsuccessful. I did it prior to TVFool, so my results were more trial and error.
I'm on a hill about 500' above Albany, NY.
The tower is 120' tall Rohn 45.
The antenna is a Channel Master 4228 old style.
The preamp is a Winegard AP 4700.
The feedline is 400' of 3/4" hardline.
The rotator is an old CDR Ham-M.
The HDTV set is a Zenith 34" CRT style with built in ATSC tuner.
I've built these filters
http://www.wa4dsy.net/cgi-bin/idbpf
It picked up analog stations in Hartford, CT; Utica, NY; White River Junction, VT; Rutland, VT, Worcester, MA; and LPTV stations in Glens Falls, NY and Cooperstown, NY. With DTV, only Utica is reliable.
I have not played with the reception for several years. With analog off the air I could try other preamps and better tuners.
