Originally Posted by k3n0bl
The TV Signal Analysis Results for my address has this station in the grey. Not sure what you would need to know exactly, but the NB (db) is -16.7 and the PWR (dbm) is -107.5. I am not sure what all that means but I assume it is a foundation for the equipment I would need?
Have you read the Signal Analysis FAQ? It will tell you what you need to know. Assuming you have read that, then you would know that chasing a station with a NM at your location of nearly -12 dB via a troposhperic scatter path is going to be very hard. Reliable reception, meaning having spare signal strength to protect against all sorts of signal fading, requires +10 dB NM. You would need an antenna with 22 dB gain (amplifiers DO NOT COUNT in this - they zero out cable losses) and that is not possible.
You will see WBNS on occasion with the typical fringe-area antenna. You just won't be sure when.
