Here's my graph:
http://www.tvfool.com/?option=com_wr...9c6bb4f85b37ec
I am trying to get stations at NYC, which are at about 260 degrees. They are about 60 miles away. I think I need a powerful antenna for upper VHF and UHF signal. The problem is all that I found in the internet were very big, especially long. I understand for weak VHF signal, this might not be avoidable, but I want to listen to you guys if there is any good compact antenna? My friend has suggested Winegard HD 7698P (
http://www.solidsignal.com/prod_disp...p?PROD=HD7698P). I found something like this: HD Stacker Antenna VHF/UHF/FM/digital/HD (
http://estore.websitepros.com/112973...-HD/Detail.bok), which is much shorter, but is it better than the Winegard HD 7698P or at least at the same level?
Finally, a totally unrelated question, can I combine the internet signal from cable company with the OTA signal? The cable here only has internet signal, no TV signal or anything else.
