The amplifier suggested back in August would have handled strong signals better, but would likely need an external FM trap between the antenna and amp input.
Originally Posted by GroundUrMast
If you are able to safely mount at 50' there is more signal available to you. A Winegard HD7698P pointing at 265° paired with an Antennas Direct CPA019 preamp will provide the networks you named plus many others.
