how does this sound? Winegard HD-7696P antenna with Winegard AP 8800 pre-amp. i figured if the 7694 was good then the 7696 would be a lil better, true?. as far as the CPA-19 pre-amp John suggested, it says its only compatible with Clearstream C1, C2, & C4. only reason i choose the 8800 instead. if Tower Guy ends up being correct i can always add a smaller antenna to the same mast correct?
