Old 15-Sep-2011, 2:51 PM   #9
Tower Guy
Originally Posted by John Candle View Post
WLFI channel 11 is Very Strong and will be received just fine with the HD7694P antenna. The HD7694P antenna receives channels 7 thru 69.
It's not a matter of signal strength, it's a matter of signal quality. A mis-aimed antenna causes multipath. If the location is open in all directions you're right, if not, a second antenna is the best solution.
