Old 23-Aug-2011, 9:29 PM   #10
MisterMe
I presume your goal is to receive WXIN-FOX, real channel 45. Others in that direction would be bonus?
How high can you safely mount a large antenna such as an Antennas Direct XG91? Please post a TVFR for that AGL.
Are you willing to use an A/B switch to select between two antennas?
Comparing the signal from WXIN in Indianapolis to WCCU, the FOX affiliate in Central Illinois, it appears that the OP will have better luck with the Illinois station.
MisterMe is offline   Reply With Quote
